we have a 4506 switch with Access Gateway Module and E1 PRI card on it.
I have configured the module as IP Telephony gateway and works just like an H323 IOS router. Before getting the 4506, we had a 2610 with NM-HDV-E1 card working as H323 gateway and was working fine. I have configured the Access Gateway Module the same way as my old 2610 router, but the problem is that although I can receive incoming calls fine, I can not call outgoing calls. As soon as I finish dialing the number, I get a fast busy signal.
Anyone found similar problem before?
