Problems with HDA and FXS ports
mkoci
We have a 2600 with a HDA (4 FXS and 8 FXO) running 12.2-11.T and configured for H323 at a remote site. The FXOs go to the PSTN and are working fine, but when I hook up to the FXS ports, it will give me a reorder tone after dialing the first digit. There is a CallManager at the Main site connected via a T1. We are running g711u everywhere.
I've placed analog phones on the FXS ports and created dial-peer pots statements for them, but could not call between the phone. When you press the first digit the reorder tone starts, like it doesn't know of the dial-peers. Has anyone run into this?
8 Replies 8
rickb
Level 3
Level 3
What do your dial-peers look like? You can put statements like "direct-inward-dial" on FXS dial peers that will cause re-order tones. The fact that you at least get dial tone sounds like something is messed up in them. Please post the config (take out all password statements, change IP addresses if they are public) and let us have a look.
Rick
Here's the config. The only other thing I had tried was putting a station id on the voice-port, but that didn't help either.
Mark
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname knox2gv
logging buffered 20000 debugging
enable secret
enable password
voice-card 1
ip subnet-zero
no ip domain-lookup
ip host cisco 172.16.50.78
ip dhcp excluded-address 172.30.0.1 172.30.0.20
ip dhcp pool IPphones
network 172.30.0.0 255.255.0.0
option 150 ip 172.16.150.2
default-router 172.30.0.1
dns-server
ipx routing 0002.fd2c.4a00
fax interface-type fax-mail
mta receive maximum-recipients 0
ccm-manager switchback immediate
interface FastEthernet0/0
description interface FastEthernet0/0
ip address 172.30.0.1 255.255.0.0
speed auto
half-duplex
ipx encapsulation SAP
ipx network 10
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.30.0.1
interface Serial0/0
ip address 192.168.0.2 255.255.255.252
ipx network B004
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
call rsvp-sync
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
connection plar 5001
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/14
voice-port 1/0/15
voice-port 1/0/16
voice-port 1/0/17
shutdown
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 49.
port 1/0/4
dial-peer voice 2 voip
destination-pattern .
session target ipv4:172.16.150.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 3 pots
preference 1
port 1/0/5
dial-peer voice 4 pots
preference 2
port 1/0/6
dial-peer voice 5 pots
preference 3
port 1/0/7
dial-peer voice 5080 pots
destination-pattern 5080
port 1/0/0
dial-peer voice 5081 pots
destination-pattern 5081
port 1/0/1
dial-peer voice 5082 pots
destination-pattern 5082
port 1/0/2
call-manager-fallback
ip source-address 172.30.0.1 port 2000 strict-match
max-ephones 24
max-dn 50
access-code fxo 9
alias exec sii show ip int brief
alias exec sdp show dial-peer voice summary
alias exec svp show voice port summary
line con 0
line aux 0
line vty 0 4
password
login
line vty 5 15
login
no scheduler allocate
end
vramanaiah
Did you check if the destination-pattern under the pots dial-peer is configured
properly?
I don't understand the question. The FXS ports on the HDA are 1/0/0 - 1/0/3. The dial-peer 5050 pots is pointed to port 1/0/0 and 5051 is pointed to 1/0/1. Now correct me if I'm wrong, but with an analog phone connected to port 1/0/0 I should be able to dial 5051 since there is a dial-peer for that number pointed to port 1/0/1. As soon as I dial the "5" I get a reorder tone. The same goes for the "4" when I try to dial "49". I know the FXO ports work because the IP phones use them for incoming and outgoing calls. At first I thought it was a problem with the call manager not knowing about the DN number of the FXS port, but that shouldn't come into play when going from one FXS port to another FXS port. I'm at a loss.
Mark
I would do a debug - debug voice ccapi inout - and watch what peer the calls match. It may be matching your VOIP peer since you have a "." (dot). Dial peers on H.323 gateways do not hit closest match necessarily - they grab the first match and go. I'm not sure what order they follow; maybe someone out there can elaborate.
Can you please cut&paste the dial-peer configs - thanks
port 1/0/4
codec g711ulaw
no vad
preference 1
port 1/0/5
preference 2
port 1/0/6
preference 3
port 1/0/7
port 1/0/0
port 1/0/1
port 1/0/2
I find it useful to do a
router# show dialplan number 5081
and see what dial-peers match the dial-pattern. If you have more than one matching, make sure the one you want has a better preference ...
