Problems with the Cisco IP Phone 7940
Hello!!
I have a Cisco IP Phone 7940, but it doesn't work. I reseted the phone, but when I pressed the button settings I cannot access to configuring settings. What can I do with this problem?.
Hope some one could help me.
Thanks.
Jaime Valencia
If the phone is registered to CUCM/CME make sure you allow the access to the settings button on the device.
java
if this helps, please rate
AndreaTornaghi
Is it registered on CUCM?
In this case did you change anything under Device>Phone>Product Specific Configuration?
Ratheesh Kumar
Hi there
If the phone in registered in CUCM, check the Setting Access Setting under Product Specific Configuration Layout
or do a factory reset
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/15254-7960-default.html#topic1
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
