Remove display info in "from" sip-header on CUBE
mcaldogne
Level 3
Level 3
Hello everyone!
Our new ITSP send in INVITE as display info the calling number and we need to remove it if possible on the outgoing dial-peer.
In this example, here the incoming SIP message:
Here the outgoing how we would need it:
I think it should be possible with the right sip-profile configuration, but I didn't find exactly how to.
Do you have an idea?
Mirko
2 Accepted Solutions
M02@rt37
Hello @mcaldogne
Define a SIP profile that will be used for the outgoing dial-peer. Within the SIP profile configuration, use the 'voice sip-strip-privacy' command to remove the display information. Apply the SIP profile to the outgoing dial-peer.
voice class sip-profiles 1
response ANY sip-header DisplayName remove
dial-peer voice X voip
sip-profiles 1
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-sip-param-mod.html
Best regards
You can do that with this if all that you want is to remove the part between From: to <sip:.
voice class sip-profiles 10
 request ANY sip-header From modify "From:(.*)(<sip:.*@.*>)" "From: \2"
 response ANY sip-header From modify "From:(.*)(<sip:.*@.*>)" "From: \2"
dial-peer voice 110 voip
 description Outbound calls to PSTN
 voice-class sip profiles 10
It does look like you're doing additional modification on the the number, but I assume that you do that with a voice translation profile/rule(s).
Response Signature
6 Replies 6
M02@rt37
Hello @mcaldogne
sip-profiles 1
Best regards
Response Signature
Hello Roger, I have similar situation.
I would like to confirm with you, if I implemented this configuration:
request INVITE sip-header From modify ".*" "Anonymous"
dial-peer voice 1000 voip
destination-pattern 1234567890
session target ipv4:10.1.1.1
session protocol sipv2
Will I remove calling number information for calls to specific number "1234567890"?
I appreciate your validation
Likely, but I have not verified it. As you're only affecting one single called number it would be easy enough to verify by a real world test.
Response Signature
Roger, thanks.
I will test it and let you know results
mcaldogne
Level 3
Level 3
Thanks for your help... if works!
@Roger Kallberg I'm already using a voice translation for the number and it was OK, but the display name was sometimes a problem.
Mirko
