10-28-2005 11:40 AM - edited 03-13-2019 11:02 AM
I have CallMgr. 4.1(3) and want to know if you can do a ring down circuit?
What I want, is that when an IP phone is picked up it automatically rings an ext.
Trae
10-28-2005 12:58 PM
You can do this by adding a Partition that just contains a translation pattern and nothing else. The trans pattern should translate nothing (a blank string) to the number you want the phone to dial.
Add this partition to a new CSS, and assign the CSS to the phone.
Aaron
10-28-2005 02:06 PM
Some details to what Aaron says -
10-29-2005 04:51 AM
Yep - that's a much nicer explanation :-)
