Ring No Answer - Force Forwarding
elbyte
Hello - is there some way to configure a phone, or the system, so that a Missed Call causes a phone to thereafter Forward All Calls to Voicemail? Thanks.
Rob Huffman
Hi Ellen,
There is no "Built-In" Phone or System setting that will accomplish this :( I am guessing that this is more of a Training issue. The best that you can do is to configure the "Foward No Answer" setting to go to Voicemail, which you have probably already done.
Hope this helps!
Rob
Thanks Rob!
