Ring tones on CME
pbuch
I am configuring a demo system on a 2811. The phones is 7960, 7920 and just about every model on the market :-)
I have found the loud ringtones for the 7920 and the Ringlist.xml. Where do i find the other ringtones listed in Ringlist.xml ?
The 7960 phones is looking for a distingtiveringlist.xml. Is it possible to make distingtive ringing on CME ?
How ?
/Per
thomas.chen
Level 6
Level 6
Set tftp-server command to allow access to the files
e.g. tftp-server flash:RingList.xml
tftp-server flash:Piano1.raw
tftp-server flash:Chime.raw
Reboot the IP Phones. When IP Phones are rebooted, the IP Phones will get the files and show the ring types in Ring Type Option list under Settings.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_9/a3rings.htm
Yes i know. The phones show the ringtones. But where do i get the .raw files from. There are no .raw files on a cme system, and i havent been able to find them on cisco.com. Guess they must be part of the CM installation kit.
/Per
There are no ring tones supplied with CME except the default two which are embedded in the phone firmware...
If you want others you could steal them from a CM installation (although the ones that come with that are fairly silly), or make your own - they're just wave files in a specific format... See this url:
See this URL for details of what spec the file has to be:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c2efa.html#xtocid3
Or you might find some on the web - e.g. this one from 24 on TV:
http://www.ccir.ed.ac.uk/~jad/ringtone.html
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
