09-10-2023 07:33 PM
Anyone knows how to configure Cisco CUBE to communicate with Avaya IP Office 500 via SIP trunk? Is it more or less the same configuration when you setup the CUBE SIP trunk to CUCM?
1. Setup the voice service voip and sip
2. Setup inbound dial-peer from ISP and outbound dial-peer to Avaya
3. Setup inbound dial-peer from Avaya and outbound dial-peer to ISP
Pretty much it? Can someone give me an example?
Thanks!
09-10-2023 10:03 PM - edited 09-13-2023 04:46 AM
In general it’s always pretty much the same base configuration for any trunk, like in/outbound dial-peers and so on. However each integration usually has its own unique set of parameters that it needs. Cisco has a quite comprehensive library of references configuration for various integrations. Have you looked at that if you find anything suitable? It might not have the exact same Avaya system, but for sure there are one for a Avaya system that you can use as a reference.
09-13-2023 03:18 AM
There are a few reference configs for Avaya on the CUBE White Papers page, but nothing specific to IP Office.
