SIP and H323 ON SAME VOICE GATEWAY
mario.valdez
We have an H323 VoIP working network, but want to migrate to SIP, our voice gateways are Cisco AS5300 with 12.2 IOS.
The question is can coexist in the same interface H323 and SIP??,
or must the gateway have a interface dedicated to just one of them.
or Just can´t we have SIP and H323 configured on the same Gateway?
thanks in advance!
yraps
Yes any IOS higher the 12.2.XX is supported both H.323 and Sip on the same gateway.
If the GW is for termination only nothing really required to be done, it is automatically synch up according to the protocol which the call originate from
If the GW is originating traffic to the IP side, you can determine the VoIP session control protocol buy assigning matching VoIP dial peer per each SIP or H.323 session.
This is my IOS version and configuration, Could you please take a few moment to feed me back??
Do I need a new RADIUS configuration for using SIP????; Do I need to configure in the as-5300 the SIP-UA anyway??? or Where do I configure the gateway for using SIP in the latest 2.2.xx IOS release?
I put some comments in the configuration below to verify if that would be the required configurations. Please take a moment to feed me back, ok? Thanks in advance for your help!!!!!!!
#show ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(6a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 01-Dec-01 11:05 by pwade
Image text-base: 0x600089B0, data-base: 0x60F10000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPL
1)
uptime is 16 hours, 23 minutes
System returned to ROM by reload at 02:10:53 UTC Sat Aug 3 2002
System restarted at 18:20:43 central Mon Aug 26 2002
System image file is "flash:c5300-is-mz.122-6a.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory
Processor board ID 18267500
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 73-2414-05,
Board Revision D0, Serial Number 18267500,
PLD/ISP Version , Manufacture Date 25-Feb-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
100 Serial network interface(s)
4 Channelized T1/PRI port(s)
60 DSP(s), 120 Voice resource(s)
128K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
#Show run
Current configuration : 5460 bytes
! Last configuration change at 19:55:01 central Wed Aug 21 2002
! NVRAM config last updated at 16:22:22 central Thu Aug 8 2002
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname xxxx
logging rate-limit console 10 except errors
no logging monitor
aaa new-model
aaa group server radius xxxx1
server xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646
aaa group server radius xxxx2
aaa authentication login default local
aaa accounting connection h323 stop-only broadcast group xxxx1 group xxxx2
################new aaa accounting for SIP?????? is this correct???##################
resource-pool disable
call rsvp-sync
clock timezone central -6
clock summer-time central recurring
ip subnet-zero
no ip finger
no ip domain-lookup
ip domain-name xxxx
ip name-server xxx.xxx.xxx.xxx
no ip dhcp-client network-discovery
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g723r53
codec preference 4 g723ar53
codec preference 5 g723r63
codec preference 6 g723ar63
fax interface-type vfc
mta receive maximum-recipients 0
controller E1 0
framing NO-CRC4
clock source line primary
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled
cas-custom 1
country telmex
category 2
answer-signal group-b 1
dnis-digits min 4 max 20
ani-digits min 0 max 10
dnis-complete
groupa-callerid-end
controller E1 1
framing NO-CRC4
clock source line secondary 1
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
controller E1 2
framing NO-CRC4
clock source line secondary 2
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
controller E1 3
shutdown
framing NO-CRC4
clock source line secondary 3
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
gw-accounting h323 ###############gw-accounting for SIP??? is this correct?###########
gw-accounting h323 vsa ##########gw-accounting vsa for SIP????########
gw-accounting voip
translation-rule 1
Rule 0 any xxxxxxxxxxx
translation-rule 2
translation-rule 3
translation-rule 4
Rule 0 any xxxxxxxxxxxx
translation-rule 5
interface Ethernet0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface FastEthernet0
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
duplex full
speed 10
h323-gateway voip interface
h323-gateway voip id xxxx ipaddr priority 120
h323-gateway voip id xxxx ipaddr xxxx
h323-gateway voip h323-id
h323-gateway voip tech-prefix 1#
###########SIP-gateway voip interface on the same interface that H323????is this correct????##############
###########SIP-gateway voip id ipaddr ????#########
###########SIP-gateway voip ???????###########
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
radius-server host xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646 key xxx
radius-server retransmit 10
radius-server timeout 60
radius-server vsa send accounting
voice-port 0:1
cptone MX
timing digit 0
timing inter-digit 0
voice-port 1:1
cptone MX
timing digit 0
voice-port 2:1
cptone MX
timing digit 0
voice-port 3:1
cptone MX
timing digit 0
dial-peer voice 1 pots
destination-pattern 01..........
translate-outgoing calling 1
direct-inward-dial
port 0:1
forward-digits 10
prefix 01
dial-peer voice 10 voip
destination-pattern 20..........
voice-class codec 1
session target ras
#####Can I have a voip dial-peer for SIP with the same destination-pattern than the one for h323...?????#####
dial-peer voice 2 pots
translate-outgoing calling 2
direct-inward-dial
port 1:1
forward-digits 10
prefix 01
dial-peer voice 3 pots
translate-outgoing calling 3
direct-inward-dial
port 2:1
forward-digits 10
prefix 01
dial-peer voice 4 pots
translate-outgoing calling 4
direct-inward-dial
port 3:1
forward-digits 10
prefix 01
dial-peer voice 5 pots
translate-outgoing calling 5
direct-inward-dial
direct-inward-dial
forward-digits 10
prefix 01
gateway
timer receive-rtcp 6
line con 0
logging synchronous
transport input none
line aux 0
line vty 0 4
scheduler interval 1000
ntp clock-period 17208026
ntp server 204.123.2.72
ntp server 128.9.176.30
ntp server 192.6.38.127
end
You at least have to create the sip-ua entry under the conf terminal section.
As for accounting the same definition that works for H.323 will apply for SIP as well, no specific configuration is required.
See my specific reference to each of you question below:
#Show run
version 12.2
hostname xxxx
no logging monitor
aaa new-model
==„» Answer: Leave intact
call rsvp-sync
ip subnet-zero
no ip finger
no ip domain-lookup
ip domain-name xxxx
voice class codec 1
controller E1 0
framing NO-CRC4
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
controller E1 1
framing NO-CRC4
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
controller E1 2
framing NO-CRC4
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
controller E1 3
shutdown
framing NO-CRC4
cas-custom 1
country telmex
category 2
dnis-complete
groupa-callerid-end
==„» Answer: Nothing required to be added for SIP
gw-accounting voip
translation-rule 1
translation-rule 2
translation-rule 3
translation-rule 4
translation-rule 5
interface Ethernet0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
duplex full
speed 10
==„» Answer Nothing required to be added here, the SIP referral will be done below under the VoIP dila-peer section
voice-port 0:1
cptone MX
timing digit 0
voice-port 1:1
cptone MX
timing digit 0
voice-port 2:1
cptone MX
timing digit 0
voice-port 3:1
cptone MX
timing digit 0
direct-inward-dial
port 0:1
forward-digits 10
prefix 01
voice-class codec 1
session target ras
==„» Answer: No, that the place to determine if you want to use H.323 or SIP. The option has we can call it call signaling negation doesn¡¦t exist.
==„» Answer: In SIP case you have to define
session protocol sipv2
session target dns:
dial-peer voice ce 2 pots
direct-inward-dial
port 1:1
forward-digits 10
prefix 01
direct-inward-dial
port 2:1
forward-digits 10
prefix 01
direct-inward-dial
port 3:1
forward-digits 10
prefix 01
direct-inward-dial
direct-inward-dial
forward-digits 10
prefix 01
gateway
line con 0
logging synchronous
line aux 0
line vty 0 4
end
YARON
I really apreciate your help, for taking the time and reply for my questions.
