10-02-2006 07:35 AM - edited 03-13-2019 03:12 PM
I am looking to deploy a 10 person voice solution. What is the smallest solution cisco provides?
10-02-2006 07:47 AM
Hi, the smallest solution is with CCM Express. See next url:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd8041c303.html
Hope helps you.
10-02-2006 11:19 AM
Thanks, just hard to justify that solution in a 10-person office, i.e. 1 internet router, 1 voice router, voice cards, POE switch, and bandwidth.
10-02-2006 11:56 AM
Erik,
You dont need two routers to do voice and internet. You can get a 2801 or 2811 ( i would prefer buyina a 11 instead of 01, but if budget is a concern 01 is fine). both routers have hwic slots which can populate voice and data cards. If you get the 2811, you can also get a nm16esw with POE that can be your 16 port switch with POE on all ports. The downside of using an 01 is that it doesnt have a Network module slot, hence you cannot use a nm16esw on a 2801.
Sankar.
10-03-2006 06:17 AM
Sounds good thanks for the info. Hard to make a decision. We like the idea of having two routers one for voice and other for data. Upgrading and maintenance seems easier when you have two devices.
10-02-2006 10:45 AM
Research the following URL to see if it is a solution that meets your needs:
