Spark Hybrid - Mutual TLS DNS Record
Felix Sarayar
Hi All,
I'm pretty new to Expressways in general.
Current environment already have EXP-C and EXP-E pair for MRA, and so they already have <_sips._tcp.domain.com> entry.
In the documentation, it says that Mutual TLS is recommended to use port 5062, and so you should also create a DNS record for this service.
My question is:
1) is it possible to create an identical DNS record _sips._tcp.domain.com but with port 5062. Will it screw things up?
In other cisco docs, it mentions the use of a subdomain to differentiate the services, _sips._tcp.sipmtls.example.com.
Davide Fiumi
Hi Felix,
did you have any updates about this topic?
Thanks.
csrlima
Level 3
Level 3
Hi ,did you solve it?
what we must to create?
1 alias sipmtls.mydomain.com pointing to my EXPRESSWAY E
1 SRV record sips._tcp.sipmtls.mydomain.com 5062  or sips_tcp.mydomain.com 5062
Needs to be sipmtls SRV record. Don't use sips tcp. Alias also will not work.
