10-13-2005 07:33 AM - edited 03-13-2019 10:51 AM
is there any other option available for speed dial on callmanager. beside these two:
1.speed dial button on the phone
2.name search in directory
10-13-2005 07:46 AM
There are also the Address Book and Fast Dials services which are described here:
Hope this helps.
Brandon
10-13-2005 11:32 AM
Use the Abbreviated Dial feature. The user configueres up to 99 Speed Dials on their CCMUser page.
Then while the phone is ON HOOK they enter the speed dial number 1-99 and press the AbbrDial softkey.
11-09-2005 11:32 AM
I am going batty here, i don't get an abbr dial key, nor can i find a place to add it under the softkey template configuration.
11-09-2005 11:43 AM
I suppose i should clarify, i cannot get it to appear on IP Communicator. Do they not support AbbrDial?
11-09-2005 12:56 PM
Take a look at the following link. Abbreviated dialing is not supported in 1.1x.
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/prod_release_note09186a008043a3ba.html
Hope this helps.
Brandon
