03-14-2006 07:14 AM - edited 03-13-2019 12:31 PM
We need an Ata for servicing a machine remote. The connection is thru the ISDN to a 2821 to the ATA and then to the Modem. The speed is only 2400 bits. How can I speed up the ATA to 56k?
Thanks for helping!
03-20-2006 07:21 AM
Officialy modems are not supported on the ATA. I think nothing much can be done on this aspect and you need to check for other alternatives.
03-21-2006 03:49 PM
What do you think about "other alternatives"?
03-24-2006 06:56 AM
we've been able to dial thru ATA's but you'll have to crank your baud rate down to like 38400 on the calling machine in order for it to work. I think you can pretty much rule out 56k.
11-20-2006 09:57 AM
Could you kindly let me know the config in the ATA and your IOS gateway that allowed the ATA's to work as a modem? We cannot get it to work no matter what we try. We're thinking of going with Linksys Sip instead to get this to work. Thanks for any help you can provide.
