05-04-2005 05:34 AM - edited 03-15-2019 03:26 AM
I'm running SRST on a Cisco 2811 12.3(11)T5. When I disconnect the WAN link to test incoming and outgoing calling, I am able to get incoming calls, but I am unable to make outgoing calls. When I dial, the router only accepts 3 digits and then attempts to dial and of course fails. We are not using MGCP with this Call Manager implementation
Here is the relevant config information:
voice-port 0/2/0
timeouts interdigit 3
connection plar 406
caller-id enable
dial-peer voice 90 pots
destination-pattern 9T
incoming called-number .
port 0/2/0
dial-peer voice 100 voip
destination-pattern ...
voice-class codec 1
session target ipv4:172.16.0.20
dtmf-relay h245-alphanumeric
no vad
call-manager-fallback
secondary-dialtone 9
max-conferences 4
ip source-address 172.16.1.1 port 2000
max-ephones 12
max-dn 12 dual-line
system message primary SRST Active
alias 1 6000 to 400 preference 2
Any help would be great!
05-04-2005 05:47 AM
This dialpeer has a match for 3 digit number so this is why 3 digits then busy.
Since your inbound connection plar goes to 406 you can change this to destination-pattern 4.. to get by this. However if you are getting other numbers on other ports you may have to add more dial-peers, or change your destination pattern, or add a translation rule to better handle the numbers.
voice-class codec 1
no vad
05-04-2005 05:55 AM
ebergquist,
Thanks for the reply. I should have included the debug statements to show that the outgoing calls are matching dial-peer 90 and not the dial-peer voice 100. I am almost wondering if I need to have a better destination pattern than 9T for the local calling.
Thank you,
Jon
