translation rule help
rwawrig
I need to translate the incoming calling number regarding the number length.
If the number have 8 or 9 digits, I need a 0 in front. If the length is less or bigger, the number should be unchanged.
I read doku, tried some expressions, but no success. Any idea how to do it ?
Thx
jasyoung
Level 7
Level 7
voice translation-rule 1
rule 1 /^\(........\)$/ /0\1/
rule 2 /^\(.........\)$/ /0\1/
and ...is working!!! Thanks a lot :)
The voice translation rules are so cool comparing with simple translation rules I used until now.
Thanks again
cheers
That's fine, but it cannot be used with a MGCP gateway, I suppose?
Frantisek Opravil
Try perhaps translation patterns in CCM.
There instead of dots for single digits you should use X. And in general translation patterns behave a bit differently, but I guess you'll get the point.
