09-12-2001 03:14 PM - edited 03-12-2019 12:33 PM
We currently have a 7825 call manager connecting to a 4604 gateway blade on a 4006. We are connected to a 5ess Phone switch at the CO and can dial long distance numbers nationwide, but when we dial international numbers, it pauses for like 10-15 seconds and then gives us a fast busy signal. I do have the debugs if anyone would like to see them. I took a debug of an international call being placed. If anyone has any suggestions as to what I can try, I would appreciate it. The email address is not the one that came with this post, but rather cbrimmer@foleylaw.com
Thanks.
Christopher Brimmer
Network Engineer - Milwaukee
Foley & Lardner - Attorneys-at-Law
E-mail: cbrimmer@foleylaw.com
09-13-2001 11:03 AM
I have a customer who had a similar problem. They had AT&T PRI service from a 4ESS switch and were getting reorder tone whenever they tried to dial an international call.
Turns out Call Manager was sending the called number type = international to the 4ESS. Once they received it, they did not want to see the "011" code. I fixed it by changing the "called Party IE Number Type" from "call manager" to "Unknown" in the call manager PRI admin screen. Could also have added a route pattern "9011.!" and set the "discarded digit" to "predot".
Rob
09-13-2001 01:26 PM
What kind of reject code you have received in ISDN trace ? I would like to take a look at it. Pls send it to keith_yam@hotmail.com
09-14-2001 08:32 PM
If this problem is still not resolved, can you please post the output of debug isdn q931 taken from the 4604 gateway when the call failed?
