Using MGCP with 1760 router
apadayhag
Can I use MGCP with a 1760 router? If yes, what version of CallManager will I use? I tried CallManager version 3.1 but the 1760 router is not present under the Gateway selection.
I really appreciate it if you can help me on this.
Thanks!
Prashanth Krishnappa
Cisco 1760 routers currently do not support MGCP. You will have to configure
the router as an H323 gateway at this time.
