VG224 cable going to ground??
ryan_oconnell
Level 3
Level 3
I'm having an amphenol 50 pin RJ-21 cable made by a cable manufacture. I sent them the pinout requirments from this URL http://www.cisco.com/en/US/docs/routers/access/vg224/hardware/installation/guide/higcabl.html#wp1043178
The cable manufacutre came back with a question regarding the pinout requirments. They want to know why they are asking for pin's 25, 50, 51, 52 to go to GND. Specifically 51 and 52 because they don't exist in a 25 pair cable.
Anyone?
Rob Huffman
Hey Ryan,
Long time my friend :) These Pins/Pairs will not go to Ground. They are completely unused. I'm guessing this diagram was copied from some other reference.
Just a plain old RJ21 (Male) like this;
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
Hope this helps!
Rob
Rob Huffman
Hey Ryan,
Cisco RJ21 Cables
Hope this helps!
Rob
Thanks Rob,
You confirmed my suspicion
Cheers Ryan
Hey Ryan,
You are most welcome my friend!
Cheers!
Rob
