Voice commands not offered on IP Plus
cunninghama
This is a followup message to a previous one. I have installed the IP Plus (image c3640-is-mz.122-15.T) package, and still do not get voice port commands. I'm also rather worried about the lack of DSPs shown.
Anyone have any ideas?
test#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(15)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 10-Mar-03 17:26 by ccai
Image text-base: 0x60008950, data-base: 0x61B20000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
test uptime is 17 hours, 44 minutes
System returned to ROM by reload
System image file is "flash:c3640-is-mz.122-15.T.bin"
cisco 3640 (R4700) processor (revision 0x00) with 98304K/32768K bytes of memory.
Processor board ID 26875901
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
24 Serial network interface(s)
1 Channelized T1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
test#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
test#conf t
Enter configuration commands, one per line. End with CNTL/Z.
test(config)#voice-port 0
^ (^ is under the -)
% Invalid input detected at '^' marker.
test(config)#dial-peer voice 1 pots
test(config-dial-peer)#port 1/0
^ (^ is under the o of port)
test(config-dial-peer)#exit
test(config)#dial-peer voice 2 voip
^ (^ is under the v of voip)
6 Replies 6
eyabane
the IOS is correct, but i think you have a hardware related problem here:
are u sure you have a voice module in that box? if so then maybe the voice card is not working properly, but foremost, if the interfaces are the right ones, then maybe you haven't configured your PRI properly yet. if you can, post the necessary config here. sometimes, just missing the "no shutdown" command on the port could cause all that you described.
E.
paul.harrison
Level 4
Level 4
What modules do you think you have in your box as opposed to the ones the oruter knows you have?
My guess is that you don't have an NM-HDV module housing that MFT-T1 interface card. But you need to confirm what you physically have.
Paul
cunninghama
Thank you both for your followups. After posting I noticed that I had a 'dial-peer voice 2 pots'. After removing that, it let me add a 'dial-peer voice 2 voip'.
Here is an sh diag. It seems correct to me, but I'm not really a Cisco expert, and have never worked on this model before. I see an NM there, but not an NM-HDV. I have no idea what to physically look for inside the router.
test#sh diag
Slot 0:
NM-1FE2W Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04796-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : JAD05480N90
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 D7 41 01 00 C0 46 03 20 00 12 BC 01
0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
0x20: 35 34 38 30 4E 39 30 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
CT1 (CSU) Port adapter, 1 port
Hardware revision 1.1 Board revision F0
Serial number 27299620 Part number 800-01228-04
FRU Part Number: NM-1CT1-CSU=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
0x20: 01 26 01 01 01 A0 8F 24 50 04 CC 04 00 00 00 00
0x30: 78 00 00 00 02 03 12 00 FF FF FF FF FF FF FF FF
and here is an sh run:
test#sh run
Building configuration...
Current configuration : 1395 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname test
boot system flash:c3640-is-mz.122-15.T.bin
logging queue-limit 100
no logging console
enable secret
enable password xxxxx
ip subnet-zero
isdn switch-type primary-ni
trunk group 1
hunt-scheme round-robin
voice rtp send-recv
voice service voip
h323
sip
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing esf
clock source internal
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 192.168.1.159 255.255.255.0
no ip mroute-cache
speed auto
full-duplex
interface Serial1/0:23
no ip address
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 30000
isdn bchan-number-order ascending
trunk-group 1
no cdp enable
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.57
call rsvp-sync
mgcp profile default
dial-peer cor custom
trunkgroup 1
destination-pattern 1234
direct-inward-dial
destination-pattern 2345
session target ipv4:192.168.1.160
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
end
test#
According to the show diag, there are no voice cards installed!!
According to the sh diag, you have a NM-1CT1-CSU= , which is not a voice capable Network Module. You need a NM-HDV which have DSPs onboard.
-ben
Ah, this would explain a lot. I'll raise this with our vendor. Thanks to everyone who responded.
