voip qos in frame-relay network
yi-chen
when i config frame-relay map,large data packet can not go through normally
c2600-js-mz.121-5.T12
c3640-js-mz.121-5.T12
related config:
interface Serial0/0
no ip address
no ip directed-broadcast
encapsulation frame-relay
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
frame-relay ip tcp header-compression
frame-relay ip rtp header-compression
interface Serial0/0.1 point-to-point
description fr to henanciq
bandwidth 128
ip address 10.41.252.26 255.255.255.252
no ip mroute-cache
frame-relay class 128k
frame-relay interface-dlci 16 IETF
map-class frame-relay 128k
no frame-relay adaptive-shaping
frame-relay cir 128000
frame-relay mincir 1000
frame-relay fair-queue
frame-relay fragment 160
frame-relay ip rtp priority 16384 16383 100
avalchev
I will sugest you the following configuration changes:
1. In 'map-class frame-relay 128k ':
frame-relay mincir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay ip rtp priority 16384 16383 ??? - you will decide how much
You must do this at both sides of the WAN link.
Your WAN Service provider must guarantee you this 128kpbs as a minimum!!!
use 'sh traffic-shape' to see if at both routers it looks like:
Interface Se3/0.6
Access Target Byte Sustain Excess Interval Increment Adapt
VC List Rate Limit bits/int bits/int (ms) (bytes) Active
884 128000 160 1280 0 10 160 -
use 'sh frame-relay fragment' to see if fragmenting works:
Serial3/0.6 884 end-to-end 160 888107 8286890 0
if the last value 'dropped-frag' is increasing - this meen that your WAN provider not gives you the CIR 128000, and drops some or more of your fragments - take apropriate action.
Good Luck!
By the way, try to remove RTP and TCP header compressions if needed - it is very buggy at most of the IOSes.
according to your suggestion the voip qos is better than before
thks a lot
