04-08-2015 01:35 AM - edited 03-13-2019 08:55 PM
Dears,
I face a problem related to VWIC E1 card that not recognized by Voice gateway router 3925. I can find the VWIC card in Show Diag command but not appear neither on Sh Version nor Sh inventory commands. also i can't find the Card type command or controller e1 command. I need your help to fix this problem.
Solved! Go to Solution.
04-08-2015 03:09 AM
Hi ,
it is is IOS issue.you need to upgrade the router IOS to 15.1(3)T
you are using 151-1.T
please refer the link with similar discussion
also refer datasheet table 1
regds,
aman
04-08-2015 05:25 AM
Hi Osama,
I opened the link shared with you which says
Cisco IOS Software Release and Cisco IOS Software Feature Set License Requirements
04-08-2015 01:47 AM
Hi Osama,
can u share show version/ show diag and show inventory of 3925 router ?
also, which VWIC model are u using and show licenses feature/show license detail
regds,
aman
04-08-2015 02:55 AM
04-08-2015 01:51 AM
Actually VWIC is not supported on 3900:
Ref: http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
It was replaced by VWIC2, which are supported.
Post the output of sh diag, sh ver, sh inventory - if your card is not vwic.
-Terry
Please rate all helpful posts
04-08-2015 03:09 AM
Hi ,
regds,
aman
04-08-2015 05:13 AM
Dear Aman and Terry,
Thanks for your efficient help
i re-seated the VWIC3 card before open this discussion. i will do IOS upgrade depending on you and Aman's suggestions but i need your confirmation about this image c3900-universalk9-mz.SPA.151-4.M8.bin.
AS i see in Datasheet that this IOS image is Compatible with VWIC3 card.
04-08-2015 05:25 AM
Hi Osama,
04-08-2015 03:42 AM
WIC Slot 1: Unknown WAN daughter card WIC module not supported/disabled in this slot Hardware Revision : 1.0 Top Assy. Part Number : 800-34654-01 Part Number : 73-13423-01 Board Revision : B0 Deviation Number : 0 Fab Version : 05 PCB Serial Number : FOC17261K0P Version Identifier : V01 Product (FRU) Number : VWIC3-4MFT-T1/E1 <<<
Its a VWIC3 card, so card is supported. As Aman has mentioned try to upgrade the IOS and hopefully it should resolve the issue. Otherwise if it still doesn't work, you can try to re-seat the card in different slot.
And last option will be to RMA the card if still doesn't fix the issue.
-Terry
