Nexus Data Broker Embedded
kashif.kamal
I have configured embedded NDB on a Nexus 93180YC-FX switch but when I try to add the same switch as a device in the NDB it is giving me error "Unknown Error", I am using the switch Management IP.
Also I am not sure if there is a license required to enable the Embedded NDB.
Hi thank you for your support. I have managed to make it work. I was missing the command
"nxapi http port 80", after configuring this command the broker connected successfully with the switch.
Sergiu.Daniluk
Hi @kashif.kamal
What do you use for NDB? NXAPI or OpenFlow? is the feature enabled?
What version of NDB and NXOS you run?
Cheers,
Sergiu
kashif.kamal
Hi @Sergiu.Daniluk,
       Using NXAPI, NDB version is 3.9-k9 and the NXOS version is 9.3.3. Please have a look at the attached error.
“NXAPI Device 10.242.100.18 reloaded, credentials are correct, rediscover the device when all the Ethernet modules are up ”
Do you think it is due to the required subscription?
Can you share "show module" and "show run" from the switch?
Sergiu
