05-05-2014 08:29 AM - edited 03-01-2019 07:34 AM
Hello All,
I was able to get the FEXes in diagram "EvPC_standard_config.jpeg" working.
o
But I got the following doubt, is it possible to config the FEXes as if they were in only one EvPC? I mean, is it possible to get the "EvPC_Po500.jpeg" diagram working? Why? Why not?
Thanks in advance,
Fernando
Solved! Go to Solution.
05-06-2014 07:16 PM
The only place I can find your second option is here, see Figure 9.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/guide-c07-730115.html
I think however that there might be an error in the diagram concerning vPC and the FEXs. I sent some feedback querying the diagram but have not received a response yet.
Don't forget to rate all helpful posts.
05-05-2014 07:09 PM
Have you seen this guide?: http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_enhanced_vpc.html#wp1161967
There is no mention of the second option in this guide.
05-06-2014 11:07 AM
Thanks Sean for your reply!
Yes, I've read a lot of documents and guides and I was not able to find the way to do it. I just wanted to be sure that I was not missing anything.
Thanks again!
Fernando
05-06-2014 07:16 PM
05-07-2014 01:07 PM
Hi Sean,
thanks! As you said, figure 9 is what I want to accomplish, but I believe that you are correct when you say that it might be an error there.
I will wait a couple of days more, if nothing else appears, I will mark the question as answered.
Thanks again for your assistance!
Fernando
