05-30-2019 07:56 PM
Hi!
Have you ever experienced in HX deployment, installer was stucked at starting. WE're currently adding a node in a cluster and We're using the same installer we used in creating the cluster. new node is the same as the existing nodes.
06-05-2019 06:54 AM
You can try to reset it by going to https://$InstallerIP/api/reset. Alternatively, SSH to the Installer VM and `restart stDeploy`. /var/log/springpath/springpath_validation.log may also point you in the right direction.
06-14-2019 12:34 AM
Already solved by TAC. solution is to breakdown the standard expansion workflow in UCSM + Hypervisor config and Deploy
06-15-2019 03:33 AM
So you selected the I know what I'm doing workflow?
07-31-2019 02:37 AM
Yes
05-25-2020 11:32 PM
