Nexus 5596 upgarde
ahmede_2
I'm trying to upgrade Nexus 5596UP to version 7
I used the command
install all kickstart bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin system bootflash:n5000-uk9.7.0.1.N1.1.bin
verifying image bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.0.1.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Extracting "kickstart" version from image bootflash:n5000-uk9-kickstart.7.1.1.N1.1.bin .
Extracting "bios" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.7.0.1.N1.1.bin.
Recommended action::
"Module 1 2 3 might not be supported in the new image,
it should be powered off before proceeding with install".
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1        no             n/a           n/a  Incompatible image
     2        no             n/a           n/a  Incompatible image
     3        no             n/a           n/a  Incompatible image
   101       yes      disruptive         reset  Forced by the user
   102       yes      disruptive         reset  Forced by the user
   103       yes      disruptive         reset  Forced by the user
Images will be upgraded according to following table:
Module             Image         Running-Version             New-Version  Upg-Required
     1            system             6.0(2)N2(7)             7.0(1)N1(1)            no
     1         kickstart             6.0(2)N2(7)             7.1(1)N1(1)            no
     1              bios      v3.6.0(05/09/2012)      v3.6.0(05/09/2012)            no
     1         power-seq                    v7.0                    v7.0            no
     1            SFP-uC                v1.1.0.0                v1.0.0.0            no
     2         power-seq                    v1.0                    v1.0            no
     3         power-seq                    v1.0                    v1.0            no
   101             fexth             6.0(2)N2(7)             7.0(1)N1(1)           yes
   102             fexth             6.0(2)N2(7)             7.0(1)N1(1)           yes
   103             fexth             6.0(2)N2(7)             7.0(1)N1(1)           yes
     1   microcontroller                v1.0.0.2                v1.0.0.2            no
But I'm getting the error message
then the upgrade aborts.
Any advice please
The reason or the error is because you are using different kickstart and system image
kickstart is for 7.1.1 (n5000-uk9-kickstart.7.1.1.N1.1.bin)
System is for 7.0.1(n5000-uk9.7.0.1.N1.1.bin)
try using the same image for the upgrade.
-Raj
ahmede_2
XXXXXXXXXX# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 6.0(2)N2(7)
  system:    version 6.0(2)N2(7)
  Power Sequencer Firmware:
             Module 1: version v7.0
             Module 2: version v1.0
             Module 3: version v1.0
  Microcontroller Firmware:        version v1.0.0.2
  SFP uC:    Module 1: v1.1.0.0
  QSFP uC:   Module not detected
  BIOS compile time:       05/09/2012
  kickstart image file is: bootflash:///n5000-uk9-kickstart.6.0.2.N2.7.bin
  kickstart compile time:  4/28/2015 5:00:00 [04/28/2015 13:37:44]
  system image file is:    bootflash:///n5000-uk9.6.0.2.N2.7.bin
  system compile time:     4/28/2015 5:00:00 [04/28/2015 15:53:45]
Hardware
  cisco Nexus 5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8253868 kB of memory.
  Processor Board ID FOC193605N5
  Device name: XXXXXXXXXXX
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 0 hour(s), 40 minute(s), 34 second(s)
Last reset at 148358 usecs after  Thu Jan 15 16:47:02 2009
  Reason: Disruptive upgrade
  System version: 6.0(2)N2(2)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Show module
Mod Ports Module-Type                         Model                  Status
1   48    O2 48X10GE/Modular Supervisor       N5K-C5596UP-SUP        active *
2   16    O2 16 port flexible GEM             N55-M16UP              ok
3   0     O2 GEM with L3 ASIC                 N55-M160L3-V2          ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    6.0(2)N2(7)     1.1     --
2    6.0(2)N2(7)     1.0     --
3    6.0(2)N2(7)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    8c60.4faf.de88 to 8c60.4faf.deb7         FOC193605N5
2    8c60.4f6b.26f0 to 8c60.4f6b.26ff         FOC19278J04
3    0000.0000.0000 to 0000.0000.000f         FOC19289KJX
-Raj
