Nexus 5k Fibre Channel speed issue
RyanT90
 I have a FC link on two Nexus 5000s hard set to 4gig but the speed seems limited to approx 300 Mbps. Any obvious reasons?
5 Replies 5
Rick1776
Level 5
Level 5
Can you send the configuration for those interfaces? Also are you running true Fibre Channel Switching or NPV/NPIV.
Fibre channel switching i believe
interface fc1/35
  switchport speed 4000
interface fc1/35
  switchport description ***PUL_EPR_011***
  no shutdown
vsan database
So after speaking with the customer it would appear the link is over 10km and they have no buffer credit setting in place. I'm thinking this could be a cause?
  vsan 400 interface fc1/35
For starters I would match the configuration on each side. So for instance.
interface fc1/35
switchport description ***xxxxx***
no shut
interface fc1/35
no shut
vsan database
vsan 400 int fc1/35
The buffer to buffer credits wouldn't help if you are experiencing latency on the link.
Can you provide transceiver details to verify the SFP type currently installed? on both ends.
Hmm, I was doing some research and it looks like you are correct to look at the buffer credits.
Also looks like there is a distance limitation so for 10Km it states in the link below that 800KM has a bandwidth of 1G.
Please see the link below.
https://blogs.cisco.com/datacenter/storage-distance-by-protocol-part-iii-fibre-channel
