Nexus 5k syslog issue
jonesl1
Good Morning!   I'm having some difficulties regarding our new Nexus 5020 switches.   We have two of thse in which are connected to multiple
2k models (which are being used in the Top of Rack).    We are currently utilizing the 4.1(3)N1(1) version of code.   I am still very new to these switches
and I'm not sure if it's even considered IOS or if there is another name for it.
Anyhow, here is my dilemma.   When we initially began setting these up, we noticed that there were two VRF's automatically set up (management
and default).   We are trying to set up logging to go to a remote syslog server, however....it keeps attempting to use the management vrf.    I removed the IP address from the management interface and am using VLAN 1 as my management interface (in-band management).     So....i believe this is where my
issue lies. I'm wanting to send my messages to a logging server, but use the default vrf instead of the management.    I tried using the following command:
logging server x.x.x.x 5 use-vrf default facility syslog
Unfortunately, the 'use-vrf' option doesn't show up for me.    I can't seem to figure out how to force the logging to use a certain vrf.   If anyone can help, i'd greatly be appreciated.   And once again, I'm sorry for my ignorance on this subject.
11 Replies 11
Ganesh Hariharan
Check out the below link for syslog configuration on nexus 5K
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/sm_syslog.html#wp1088182
Hope to Help !!
Ganesh.H
If helpful do rate the post
Poliberte
This was the weirdest thing. not sure if you fixed your problem but it wouldn't work for me until i hit Ctrl z after the config. Only ctrl Z worked, I still had the same issue when I typed "exit". It would always show "this server is temporarily unreachable" for me before the ctrl z. Weird!
@Poliberte
The same in my situation. Ctrl+Z is the solution :)
I was having the same exact issue with "this server is temporarily unreachable" for all my logging servers, but on a Nexus 9372 version 7.0(3)I2(2d)
I had to hit ctrl+z after each logging server command instead of enter.
How did anyone figure that one out!
Luck!! I used ctrl-z and exit depending on the mood i'm in lol. It just happened that I was working on 2 different nexus environemnt. One work and the other didn't. The only difference was that I used ctrl-z rather than exit, lol. Just a stroke of luck.
I had the same problem but i resolve with the next steps:
Workaround:Run following commands:
(config)# no logging server x.x.x.x 5 use-vrf management facility local6
(config)# logging server x.x.x.x 5 facility local6
(config)# logging source-interface loopback 0
(config)# logging server x.x.x.x 5 use-vrf management facility local6
(config)# no logging source-interface loopback 0
This is in response to the Nexus 7000 series bug, right? I tried this solution first even though i was on a 5k series to no avail, but glad it worked for you !
This worked for me.
no logging server 10.82.131.10
logging server 10.82.131.10 5 facility local6
logging server 10.82.131.10 5 use-vrf management facility local6
switch01(config)# loggin server 1.1.1.1 5 use-vrf default
switch01(config)# sho run | in "logging s"
logging server 1.1.1.1 ----notice no options display
switch01(config)# loggin server 1.1.1.1 facility syslog
logging server 1.1.1.1 5 use-vrf default facility syslog 
now those options are visible??   Does that mean it took the options, or they aren't active unless a facility is defined?
The logging server level of 5 is default.   "use-vrf default" is default.  Neither will appear in the running configuration of nx-os.  Not sure at what version this changed.
logging server 1.1.1.1 5 use-vrf management <--If I specify a vrf other that default
switch-01(config)# sho run | in "logging server 1.1.1"
logging server 1.1.1.1 5 use-vrf management <-- Level and vrf appears
switch-01(config)# logging server 1.1.1.1 5 use-vrf default <-- reset to default value
logging server 1.1.1.1 <--level and vrf are gone
switch-01(config)# logging server 1.1.1.1 4 use-vrf default <-- 4 instead of 5 of logging level
This worked for me, Thank you!!!
