Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 7004 integration with Cisco 6500 catalyst
I am planning to redesign the DC by replacing the
existing 6500 catalyst cores with Nexus 7004
and introducing an  access layer with multiple 6500 catalyst , nexus 5500 and nexus 2200 as access switches.
Are there any known issues for Nexus 7004 as core integration with 6500 catalyst as accesss ?
Any limitations to be considered while adding access-layer to Nexus 7004 ?
Diana
5 Replies 5
Andras Dosztal
Level 3
Level 3
I don't think you'll have any problems, however a more detailed topology would help to be sure. Also, here's a whitepaper about N7k vPC integration with Cat6.5k VSS.
Oleksandr Nesterov
Hi DIana.
There shouln't be any incompatibility issues.
Just be sure that you have checked switch data-sheets to be aware abut capabilities of the devices:
http://www.cisco.com/en/US/products/ps9402/products_data_sheets_list.html
and plan your topology properly.
HTH,
Alex
Hi ,
Thanks for your reply.
Actullay I am planning to setup a pair of Nexus 7004 each with M2 series 24-port card. Connect them via VPC and configure them as L3 Core switches. Downstream to these cores , I have plans to connect 4 x 6500 catalyst as access switches and 2 pairs of Nexus 5548 with Fex associated on them.again as access switches.
I see no problems with Nexus 5500 integration with Nexus 7004, but not sure how well the 6500 catalyst can integrate with Nexus 7004.
Thanks in Advance
Diana
Hi Diana.
What do you mean under the term "integration".
If you are concerned about LACP, STP, VTP and routing protocols - there shouldn't be any issues.
VPC from the cat 6k side will be considered as standart port-channel - cat6k won't see that behind it there are 2 nexus.
Just be aware which topoligies are supported for VPC. For example you cannot run routing protocol over VPC links.
HTH,
Alex
jkilleda
Level 3
Level 3
Hello Diana,
There won't be an issues related to the topology mentioned below , it's a simple topology but just be careful about the configuration that you do on it , may be you can refer/crosscheck with a configuration guide for it .
