09-28-2011 10:31 PM - edited 03-01-2019 07:00 AM
HI Experts ,
I am having a nexus 7k swich which need to be configured for tacacs
Currently i have cisco routers and switches configured to use the tacacs with the below commands
aaa new-model
aaa authentication login method group tacacs+ local
aaa authentication login local_auth local
aaa authorization config-commands
aaa authorization exec method group tacacs+ local
aaa authorization commands 1 method group tacacs+ local
aaa authorization commands 7 method group tacacs+ local
aaa authorization commands 15 method group tacacs+ local
aaa accounting exec method start-stop group tacacs+
aaa accounting commands 1 method start-stop group tacacs+
aaa accounting commands 7 method start-stop group tacacs+
aaa accounting commands 15 method start-stop group tacacs+
ip tacacs source-interface Vlan100
tacacs-server host 192.168.1.6
tacacs-server host 10.1.22.35
tacacs-server directed-request
tacacs-server key cisco
Can anyone please tell me how to configure the same setup in nexus .
Angus
09-29-2011 06:44 AM
Start with feature tacacs+ command in nexus :-)
and the rest you can refer to the following link
http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_TACACS+,_RADIUS,_and_AAA_Comparison
any issues please post it here and I will be more than happy to help
regards
Prasad K
09-29-2011 06:55 AM
HI Prasad ,
Thanks for the reply
I neet to know the equivalant configuration for the above authorization commands in nexus .
I have configured the nexus and is working for authentication and accounting , now i need to implement the authorization part .
tacacs-server key 7 "1972"
ip tacacs source-interface Vlan8
tacacs-server host 192.168.1.6 key 7 "1972"
tacacs-server host 10.1.22.35 key 7 "1972"
aaa group server tacacs+ Tacacs
server 192.168.1.6
server 10.1.22.35
aaa authentication login default group Tacacs
aaa accounting default group Tacacs
Please let me know what changes need to be made in the ACS 5.2 .
Angus
10-03-2011 10:01 PM
HI All ,
Thanks for all your replies .
I have configured the nexus and added command attributes under shell profile .
Nexus config
server 192.168.1.6
server 10.1.22.35
aaa authorization config-commands default group Tacacs
aaa authorization commands default group Tacacs
ACS CONFIG
Under Policy Element > Authorization and permision > Device administration > Shellprofiles > profilename > custome Attributes > Add entry manual
Attribute : Shell
Requierement : Optional
Value : network-operator ( Role you requiere )
Angus
