03-15-2022 05:08 AM
I have configured embedded NDB on a Nexus 93180YC-FX switch but when I try to add the same switch as a device in the NDB it is giving me error "Unknown Error", I am using the switch Management IP.
Also I am not sure if there is a license required to enable the Embedded NDB.
Solved! Go to Solution.
03-29-2022 12:59 AM
Hi thank you for your support. I have managed to make it work. I was missing the command
"nxapi http port 80", after configuring this command the broker connected successfully with the switch.
03-15-2022 05:28 AM
What do you use for NDB? NXAPI or OpenFlow? is the feature enabled?
What version of NDB and NXOS you run?
Cheers,
Sergiu
03-15-2022 05:55 AM - edited 03-16-2022 12:00 AM
Hi @Sergiu.Daniluk,
Using NXAPI, NDB version is 3.9-k9 and the NXOS version is 9.3.3. Please have a look at the attached error.
“NXAPI Device 10.242.100.18 reloaded, credentials are correct, rediscover the device when all the Ethernet modules are up ”
Do you think it is due to the required subscription?
03-16-2022 12:33 AM
Can you share "show module" and "show run" from the switch?
Sergiu
03-29-2022 12:59 AM
