Nexus series Fabric module 1 & 2 coexisting
mhiyoshi
Level 3
Level 3
I think there are Fabric module to enhance backplane bandwidth and performance.
However basically there are 2 types of fabric module, so I would like to know whether
these types are possible to coexist or not.
[Cisco Nexus 7000 Fabric-1 Module Data Sheet]
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/Data_Sheet_C78-437760.html
[Cisco Nexus 7000 Series Fabric-2 Modules]
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/data_sheet_c78-684211_ps9402_Products_Data_Sheet.html
Best Regards,
Leo Laohoo
However basically there are 2 types of fabric module, so I would like to know whether these types are possible to coexist or not.
They "can" co-exist, however, if you want to do this long term, i.  e.  more than 2 hours, then you may as well take your FAB-2 and throw it away.  Let me explain:
The decision to allow FAB-1 and FAB-2 to work together in a single Nexus 7K chassis is purely for "hitless" or non-disruptive upgrade from FAB-1 to FAB-2 card.  When you install the first FAB-2 card into a chassis with FAB-1 card, the FAB-2 card will downgrade it's speed to match the FAB-1 card's speed.  Once you remove the last FAB-1 card will the entire Nexus 7K chassis' backplane speed go up to the speed of the FAB-2.
Does this make sense to you?
Thank you for your precious information. Yes it makes sense very much.
