Object creation logs in ACI
rohandec1980
How can i find object creation logs in ACI. I am trying to find when a particular object (EPG, VRF etc) was created.
I tried audit logs but this lists only changes made to an object.  The "events" tab also doesnt list anything.
Rohan
Hi @rohandec1980
I do not think the version is the problem - I am running 3.2 train release as well.
I believe that the creation log was overwritten if the object was created long time ago. In the end, there is a configurable limit of preserved logs. You can modify it in Admin > Historical Record Policies > Controller Policies > Controller Audit Log Retention Policy  and increase the value of Maximum size (records).
If you create a new EPG, do you see the creation log?
Stay safe,
Sergiu
5 Replies 5
julian.bendix
Level 3
Level 3
Hey Rohan,
wasn't sure so just checked myself.
Couldn't find a thing..
Was looking through the files via CLI,
even there in the summary-file for a MO, you just see a field "modTs" which is the timestamp of the last modification.
Nothing found on when objects were actually created..
Sorry
Juls
Sergiu.Daniluk
Hi @rohandec1980
You should see the creation event in the Audit logs
Stay safe,
Sergiu
Thanks a lot Segiu, Juls.
I cannot see object creation logs under Auditlogs. Auditlogs only show modification to an object. I am running 3.2(1m) code,
Is there any modification/configuration required to default auditlogs setup for it to start recording events related to object creation?
Rohan
Hi @rohandec1980
Stay safe,
Sergiu
Hi Sergiu
You are right, i see the logs for new EPG creation in auditlogs.
Rohan
