Bookmark
Subscribe
39216
Upgrade Nexus 5548 from Layer 2 to Layer 3
telecastle
We are planning to upgrade our Nexus 5548 switches from the standard Layer 2 configuration to Layer 3 configuration, using the
N55-D160L3 daughter card. Do we need to purchase a separate license for the Layer 3 capability or can we use what we already have?  Currently, we are running the following firmware on our Nexus 5548 swtiches:
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(1)
  system:    version 5.0(3)N2(1)
  power-seq: Module 1: version v3.0
             Module 2: version v1.0
             Module 3: version v2.0
  uC:        version v1.2.0.1
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.0.3.N2.1.bin
  kickstart compile time:  6/13/2011 6:00:00 [06/13/2011 13:43:33]
  system image file is:    bootflash:/n5000-uk9.5.0.3.N2.1.bin
  system compile time:     6/13/2011 6:00:00 [06/13/2011 15:33:42]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8299528 kB of memory.
NX5K-A# show license usage
Feature                                               Ins       Lic       Status      Expiry      Date      Comments
        Count
FCOE_NPV_PKG                                 No         -        Unused             -
FM_SERVER_PKG                               No         -       Unused             -
ENTERPRISE_PKG                                 No      -        Unused             -
FC_FEATURES_PKG                              No      -        Unused             -
LAN_BASE_SERVICES_PKG                  No       -        Unused             -
LAN_ENTERPRISE_SERVICES_PKG        No    -        Unused             -
9 Replies 9
Collin Clark
As usual, it depends. Below is the details of the default base license and the Enterprise license. Hope it helps.
Layer 3 Base License
The Layer 3 base license (N55-BAS1K9) is included with the Cisco Nexus 5500 Platform switch. The license provides the following support:
Connected, Static, RIPv2, OSPF (256 Dynamically Learnt Routes), EIGRP-Stub, HSRP, VRRP, IGMPv2/3, PIMv2, RACLs, uRPF
Layer 3 LAN-Enterprise License
The Layer 3 LAN Enterprise license (N55-LAN1K9) includes the following:
All base license features
Full EIGRP
Unrestricted OSPF routes
BGP
VRF-Lite
great
Jerry Ye
Looks like you don't have any required L3 license. Like Collin said, you need minimum of Layer 3 Base (
LAN_BASE_SERVICES_PKG).
Please take a look at Table 2:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/Cisco_NX-OS_Licensing_Guide_chapter1.html
HTH,
jerry
Lucien Avramov
Level 10
Level 10
You need at least a base license, which is free of cost. Just contact your account team or TAC.
can we have 5500 Layer 3 capability without L3 daughter card?
Without the L3 daughter card, the 5500 is nothing but a Layer 2 switch.  You can connect a router that will do the routing OR if you have a Nexus 7K upstream with an F1/M1/M2 or F2 card, then it's possible.
When we list the available features for each license package on the cisco nexus licensing guide (page 5)
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide.pdf
the  N55-BAS1K9 provide unresitrcted OSPF routing capabilities. but on the Cisco web site they seen that the
N55-BAS1K9 provide a limited (256 routes) learned via OSPF.
Please would you confirme witch one is correct?
N.B : the hardware plateforme is NX5K 5596UP with L3 Routing module 160Gbps.
regards
umeshagroya
as
Romain M-R
Hello, I need to upgrade N5K I've the lastest licences, But I don't know how do .. Do you have any best practice to upgrade them ? thanks all for your replies,
