12-03-2015 12:36 AM - edited 03-01-2019 08:06 AM
12-07-2015 09:29 AM
That Correct, As per best practice and recommendation it is always better to have an additional Layer 2 trunk port-channel as an interswitch link to transport non-vPC VLAN traffic.
This is something vPC guideline and practices. Switches which can be configured in vPC domian will follow this thumb rule.
Have look on vPC Guideline and Best Practices for more information.
Hope it Helps..
-GI
Rate if it Helpss
12-03-2015 08:13 PM
The PortChannel connecting the vPC peers should carry all the VLANs used by the vPC member ports.
In addition, it is possible to carry also the VLAN used by orphaned ports with some special considerations.
As a general best practice, the VLANs you use for vPC-connected devices should be different from those you use for single-port attached devices (orphaned ports), and you should put those VLANs (the non-vPC VLANs) on a trunk that’s different from the one on which the peer link resides.
On the Cisco Nexus 7000 Series, when carrying vPC and non-vPC VLANs on the peer link, you may want to exclude the orphaned ports SVIs from the default behavior.Alternatively, you can use different VLANs for vPC-connected devices and single-port attached devices (orphaned ports), and put the non-vPC VLANs and the peer link on different trunks.
This recommendation applies to the aggregation layer only, not to the access layer.
Hope it Helps.
-GI
Rate if it helpss
12-03-2015 11:37 PM
you said
" As a general best practice, the VLANs you use for vPC-connected devices should be different from those you use for single-port attached devices (orphaned ports), and you should put those VLANs (the non-vPC VLANs) on atrunk that’s different from the one on which the peer link resides."
In aggregation layer there are ,
1 ) multiple single homed devices connected (non vpc member port ) on Aggregation switch
for example vlan 2 and vlan 5 an
2) switch 3750 connected (trunk) for some reason on aggregation switch .
So we need to create another trunk in between both aggregation .. Please correct me if i am wrong .
( can you share some sample configuration ) .
3 . For non vpc vlan how the traffic flow ?
4 . What about the STP configuration for non vcp vlans ?
configuration below and topology attched .
acc-sw1
interface Ethernet1/10
switchport mode trunk
spanning-tree port type edge trunk
desc connection to esx
acc-sw1
interface Ethernet1/11
switchport access vlan 3
desc connection to server
aG-sw1
interface Ethernet1/47
description connection to 3850-sw1
interface Ethernet1/8
switchport access vlan 2
aG-sw2
description connection to 3850-sw2
sw1
interface gi0/2
description connection to aG-sw1-e1/47
interface gi0/1
connected host -1
sw2
interface gi0/2
interface gi0/1
connected host -1
interface port-channel50
spanning-tree port type network
vpc peer-link
vPC Peer-link status
id Port Status Active vlans
1 Po50 up 1-4,6,9,11-17,25,33-35,50-51,64-65
Thank you for your reply .
12-04-2015 10:19 PM
Hello ,
Let me try to explain in different with some example.
A vPC port is a port that is assigned to a vPC channel group. The ports that form the virtual PortChannel are split between the vPC peers and are referred to as vPC member ports.
A non-vPC port, also known as an orphaned port, is a port that is not part of a vPC.
Below diagram shows different types ports connected to a vPC system. Switch1 and Host 3 connect via vPCs.
The ports connecting devices in a non-vPC mode to a vPC topology are referred to as orphaned ports. Switch 2 connects to the Cisco Nexus Switch with a regular spanning-tree configuration: thus, one link is forwarding, and one link is blocking. These links connect to the Cisco Nexus Switch with orphaned ports.
Hope it Helps..
-GI
Rate if it Helpss
12-05-2015 06:01 AM
Hi Ganesh ,
Thank you for the detailed explanation . If i have server connected to a port (orphaned port or non vpc port ) and vlan 60 (Peer link: vlans 10-50 in your picture .) As you said for vlan 60 (here vlan 60 non vpc vlan ?) , we need to create a separtate trunk ?
Correct me if i am wrong ?
What are the drawbacks if we did not create separate trunk ?
what if we go for n9k?
Thank you
12-07-2015 09:29 AM
Hope it Helps..
-GI
Rate if it Helpss
12-13-2015 08:09 PM
Hi Ganesh,
You were really helpful. Thank you so much .
could you provide a topology diagram wth vpc and non vpc vlan , how traffic flow if peer link alive and fail cases .
It would be really grateful .
Thank you
12-15-2015 08:17 PM
Thanks for your appreciation.
Please have look on the below link on page 6 and 7 where a clear traffic flow is show for vPC lan traffic.
http://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/C07-572835-00_NX-OS_vPC_DG.pdf
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_vPC.html
Hope it Helps..
-GI
05-12-2017 09:03 AM
Hi Ganesh,
Im running MST in DC and my Non vpc trunk is in alt blk state.I need this also to run L3 ospf adjaceny over vlan as well since i dont want to run it via peer link.
NEXUS01-SFARM# sh spanning-tree
MST0000
Spanning tree enabled protocol mstp
Root ID Priority 32768
Address 0038.df32.6700
Cost 0
Port 4195 (port-channel100)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768 (priority 32768 sys-id-ext 0)
Address 00de.fb57.27c4
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 200 128.4096 (vPC) P2p
Po2 Desg FWD 200 128.4097 (vPC) P2p
Po3 Desg FWD 200 128.4098 (vPC) P2p
Po4 Desg FWD 200 128.4099 (vPC) P2p
Po11 Root FWD 200 128.4106 (vPC) P2p
Po12 Desg FWD 200 128.4107 (vPC) P2p
Po100 Root FWD 1000 128.4195 (vPC peer-link) Network P2p
Po200 Altn BLK 1000 128.4295 Network P2p
02-20-2019 03:41 AM
Hi Ganesh,
You can try enabling separate MST instance for non-VPC VLANs, it should work.
Dinesh Kumar EKambaram
12-04-2015 07:47 PM
vpc vlan is which carried over vpc peer-link
non vpc-vlan's are modtly used for orphan ports case
