04-25-2005 10:51 AM - edited 03-02-2019 10:34 PM
Having some issues with connecting a Extreme Black Diamond, with Cisco 6506. Bundling 4 802.1q Gigabit trunks into a Channel-group(Port-channel). We cannot use PAgP(Cisco proprietary ). So, we tried LACP, which is IEEE 802.ad(?) almost connects, but cannot get a ping through. Defined the VLAN within the same subnet on both sides, and can see some traffic on the first gig interface. Where do I get more info on this, and has someone out there connected Cisco-Extreme with a Etherchannel, or just a Trunk, 802.1q
Appreciate any help
Nick
04-25-2005 01:14 PM
Can you paste the configuration of the 6506? Also, what is the IP address of the Extreme switch?
04-27-2005 02:56 PM
Is it true that you have to turn on the LACP channel protocol on each interface participating in the channel-group ? like this
interface>channel-protocol lacp
04-27-2005 03:26 PM
This is optional. Once you have "channel-group x mode active" or "channel-group x mode active", LACP is triggered.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/channel.htm#wp1020670
If you want to, you can enable it but it is not a requirement.
