09-29-2004 08:29 AM - edited 03-02-2019 06:52 PM
Over the past couple of weeks I've had numerous problems pop-up when we relocated our office and changed upstream providers. Most of those problems have been addressed and fixed. However, I still seem to have an ongoing problem that I do not know how to fix.
the problem is as follows:
I connect to my upstream via fiber interface with the IP address of 63.166.76.254 (my side of interface). I have been monitoring this inferface for a couple of weeks now and it is running error free. My internal net Interface is F0/0 which is 69.45.250.1/24 (I recently moved this to F5/0).
The problem is when pinging 69.45.250.1 I receive 50% + packet loss. When pinging the 63.166.76.254 address with a count of 1000 there is no packet loss whatsoever. It seems that anything I ping past the upstream interface is dropping at least 50% of the packets.
I have a static route of 0.0.0.0 0.0.0.0 63.166.76.253 (upstream interface). I have seen this problem before a few years ago and I do not remember the fix. All of the traceroutes from the outside appear to be fine. Any suggestions?
Thanks in advance,
Troy
09-29-2004 08:53 AM
This is a very odd problem indeed. Can you post the config of your router for us to see. The first thing I would check on your ethernet interface though is to ensure you don't have some speed or duplex issue. Also if you ping from the router to 63.166.76.253 do you drop any packets there or just from the ethernet side. Have you tried doing a ping from your router using the ethernet interface as the source and see if you have the same problem. It could be a routing issue with your ISP, maybe its trying to do some sort of load balancing.
09-29-2004 09:40 AM
Sure I'll post the config at the bottom of this message. I had previously wiped the config to start from scratch to make sure I didnt have anything in the config that would cause this problem. This routers F5/0 is plugged directly into a machine just to keep it in an upstate. I had re-arranged my network to go around this problem. So basically the 7206 is just sittting there until I can find the fix.
To answer your question about pinging upstream interface, there is no packet-loss at all.
Basic config:
Current configuration : 1789 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname ds-rtr
logging queue-limit 100
enable password **********
ip subnet-zero
ip cef
no ip domain-lookup
call rsvp-sync
controller T1 1/0
framing esf
linecode b8zs
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/2
framing esf
linecode b8zs
controller T1 1/3
framing esf
linecode b8zs
controller T1 2/0
framing esf
linecode b8zs
controller T1 2/1
framing esf
linecode b8zs
controller T1 2/2
framing esf
linecode b8zs
controller T1 2/3
framing esf
linecode b8zs
interface FastEthernet0/0
description
no ip address
no ip redirects
no ip proxy-arp
load-interval 30
shutdown
duplex full
interface Ethernet3/0
no ip address
shutdown
duplex half
interface Ethernet3/1
no ip address
shutdown
duplex half
interface Ethernet3/2
no ip address
shutdown
duplex half
interface Ethernet3/3
no ip address
shutdown
duplex half
interface Serial4/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
serial restart-delay 0
interface FastEthernet5/0
ip address 69.45.250.1 255.255.255.0
no ip proxy-arp
no ip redirects
no ip route-cache
no ip mroute-cache
load-interval 30
duplex full
interface FastEthernet6/0
description Uplink
ip address 63.166.76.254 255.255.255.252
no ip redirects
no ip proxy-arp
no ip route-cache
no ip mroute-cache
load-interval 30
duplex full
ip classless
ip route 0.0.0.0 0.0.0.0 63.166.76.253
no ip http server
snmp-server community ******** RO
snmp-server enable traps tty
dial-peer cor custom
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password ********
login
end
09-29-2004 11:00 AM
I am a little confused because you state in your first post
"It seems that anything I ping past the upstream interface is dropping at least 50% of the packets."
But you state in your second post that you don't have any packet loss to 63.166.76.253. So from what I get right now is that
1. From the workstation you get packet loss pinging to 69.45.250.1
2. From the workstation you are good to IP 63.166.76.254
3. From the workstation you are good to IP 63.166.76.253
4. From the workstation you get packet loss pinging anything after 63.166.76.253
5. From the router with a source of Fa5/0 to IP 63.166.76.253 ?? Is this good?
6. From the router with a source of Fa5/0 to anything after 63.166.76.253 ?? Is this good?
I would hardcode the speed and duplex on the workstation too. Have you used a differnt workstation? Have you tried a different ethernet ports on the router for both the local and remote side?
