827 Router Config problem
dvereecken
I am doing a migration of all our ADSL routers (non-cisco) to 827 Cisco router. Until now I had no problem at all.
But with one I have a routing problem :
This is my config :
Cisco827#sh run
Building configuration...
Current configuration : 1199 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco827
no logging buffered
enable secret 5 $1$WQwL$79u5MHQfXmZA9C1Ng3gc30
enable password 7 0101090B4F
username xxxxxx password 7 0316540412
ip subnet-zero
ip name-server 195.238.2.21
ip name-server 195.238.2.22
vc-class atm office
inarp 30
inarp 30
encapsulation aal5snap
interface Ethernet0
ip address 10.16.5.1 255.255.255.240
ip nat inside
load-interval 30
no keepalive
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
description Cisco 827 ADSL PRO
ip address 194.78.209.222 255.255.255.0
ip nat outside
pvc 8/35
class-vc office
ip nat inside source list 130 interface ATM0.1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 194.78.209.1
ip http server
access-list 130 permit ip any any
no cdp run
line con 0
exec-timeout 120 0
logging synchronous
stopbits 1
line vty 0 4
exec-timeout 120 0
password 7 095E41060D
login local
length 0
scheduler max-task-time 5000
end
As you can see , quite an easy config which I did on every router. But on this setup I can ping from my laptop (connected to the router) to 10.16.5.1 and to the WAN IP adress. But I can't ping to the WAN Gateway 194.78.209.1. And on the router I can't ping to my WAN interface and to my WAN Gateway.
Alle the WAN IP addresses and VPI/VCI are OK because I copied them from the non-cisco router.
Probably I am missing something but I can't think of what.
Thanks in advance for the help.
dvereecken
Something I forgot : I have a good connection to the DSLAM (CD led is green)
But if I do a debug atm packet :
I get ATM0(I): VCD:0x0 type:0x0Inactive or not configured VCD length:0x38
I hope this could help you
tepatel
first, the "encapsulation ..." command is missing in the config. Also you need to know what kind of technology that adsl line is configured for.
Is it RFC1483 bridging or routing, RBE, PPPoE or PPPoA etc.
Once you have that information, here is the same sample config for that
For RBE
http://www.cisco.com/warp/customer/794/827rfc_6400rbe_1.html
For PPPoA/PPPoE
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?
p=Internetworking:PPPoE__PPPoA__PPP_over_Ethernet__PPP_over_ATM&viewall=true
For RFC1483 bridging
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Internetworking:RFC_1483_Bridging___Routing&viewall=true
