campus network LAN
bgbenga
i am deploying a campus network for a client with 50 user workstations ,the client specifically requested a 4003 catalyst switch bundle as the network switch,am not sure the type of access switch or is it hub to use at the access layer,? ps advice
Prashanth Krishnappa
CAT4003 is a switch and not a hub. If you are looking for more features, you can buy a CAT4006(6 slot) with a Sup 3. You can find more info on CCO
http://cio.cisco.com/warp/public/44/jump/switches.shtml
bflanary
This is really not enough information to go on.
What are the physical locations of users relative to the 4003?
distances...buildings...rooms...
If they are relatively close, the 4003 with a couple 48 port modules will do..or you could add a couple of smaller fixed configuration switches as access layer switches.
