Can a router with AC power be supplied by a DC source ?
Custumer have in the environment a ELTEK 125 VDC supply voltage and wants to use a ASR920 with a AC power supply (100VAC - 220VAC), is this work in the specifications ? Will this work ? Is there a problem with warranty ?
5 Replies 5
marce1000
        - It can only work if it has a DC power supply (too).
 M.
Hi M. , thanks, but it is not true, any AC power supply has a rectifier in
the input that convert the input voltage RMS to some kind off DC input
with a great ripple, only after the converter that we have the final DC.
The point is, if we have enough DC input we can supply a AC power supply,
but this input DC value has a minimum, and I want to know which one value
is this minimum.
balaji.bandi
No you can not, But you can have converted DC to AC and connect if you like to use.
BB
 @balaji.bandi  FYI :
       https://www.cisco.com/c/en/us/td/docs/routers/asr920/hardware/installation/guide/b-asr920-ic-hig/m-hw-installation.html#task_1338087
 M/
@marce1000  appologies - have i missunderstoood the question :
OP - Can a router with AC power be supplied by a DC source ?
I have done some DC to AC converter as long as you get AC output, Router not mind here.
Do i miss anything ?
BB
