Cat4500 power supplies
klaudia
Hi there,
can anybody tell me whether the power supplies in Cat4500 are hot swappable?
pflunkert
Level 4
Level 4
the power suplies are hot swappable, but you have two possible modes:
The Catalyst 4500 series switches support two power management modes:
Redundant mode:Redundant mode uses one power supply as a primary power supply and the second power supply as a back-up. If the primary power supply fails, the second power supply immediately supports the switch without any disruption in the network. Both power supplies must be the same wattage. A single power supply must have enough power to support the switch configuration.
Combined mode:Combined mode uses the power from all installed power supplies to support the switch configuration power requirements. However, combined mode has no power redundancy. If a power supply fails, one or more modules might shut down.
By default, a switch is set to redundant mode. In the show power command, if the power supplies needed by system is 1, the switch is in redundant mode; if the power supplies needed by system is 2, the switch is in combined mode.
Peter
pflunkert
Level 4
Level 4
Peter
klaudia
Hi Peter,
that is EXACTLY the answer I need. Thanks a LOT for your prompt helpful info!
Klaudia
Hi Klaudia,
I'm really pleased, that i can helped you.
Peter
