02-21-2002 03:03 AM - edited 03-01-2019 08:34 PM
Ive got a Cat5505 with a corrupt image in flash so I cannot boot from the supervisor flash. I bought a pcmcia flash card because of this, preloaded with an image so i could boot in rommon mode from the flash card. However, when I try this I get a 'bad file magic number' error. The full out put is below...
rommon 1 > dir slot0:
File size Checksum File name
3197488 bytes (0x30ca30) 0xdf2eab5c cat5000-sup.5-5-10.bin
5281067 bytes (0x50952b) 0xcbbebc94 cat5000-sup3_6-2-2.bin
rommon 2 > boot slot0: cat5000-sup3_6-2-2.bin
loadprog: bad file magic number: 0x0
boot: cannot load "slot0: cat5000-sup3_6-2-2.bin"
rommon 3 >
rommon 3 >
02-21-2002 12:56 PM
Hi Samantha,
I think you can intall the Cat IOS by using "xmodem". What you need to do is you have to have TFTP server with the Cat IOS image on it, then from you console which is rommon 1> xmodem PLEASE DON'T ENTER YET. From your Hyper terminal menu tab go to "Transfer" and choose "Send file" then click the browse and select the "cat5000-sup.5-5-10.bin" with out the quote of course. Click send and you will see a new window then you go to your rommon 1> xmodem command line and press enter. I takes a lot of time to copy but it is possible to do it. good luck
02-21-2002 02:49 PM
Hi Samantha,
Check your hardware and verify that you have a Supervisor 3 module in the Cat5505. The image you tried to load was a SUP3 image (cat5000-sup3_6-2-2.bin). The old image was for a Supervisor 1 module (cat5000-sup.5-5-10.bin).
If your hardware is correct, you may also want to verify the 6.2.2 image size. You may have a corrupted image on the PCMCIA card too.
Hope this helps
JK
02-22-2002 12:52 AM
thanks for the replys.
I cannot use the xmodem download because you need version 5.1.1 (or something) Rom monitor, whereas I only have 3.1.2.
The Supervisor Card is definitely III, and the Flash card is brand new, I bought it to recover this switch! Itd preloaded with two images, one for Sup2 and one for Sup3. Anymore ideas?
02-22-2002 09:47 AM
I am guessing that you are running a Sup 1 card , you are trying to load a sup3 version which will not load .
Even if you get a valid sup 1 image your code is so old that it will be a 2 hop process to get into the 4.X train . I believe you have to upgrade to 3.2.4 first then into the "4" train , the last version for sup 1 is 4.5.13 . Do not believe the Sup 1 card supports 5.X code . Look at the module number for the supervisior and verify what Sup you are running .
02-22-2002 09:55 AM
Also check your RAM requirements , 5.X train needs 32 meg of DRAM , 6.X train requires 64 meg of DRAM .
02-26-2002 08:02 AM
no, its a sup3 card.
ive fixed it now by not putting a space before the file name! Typical...
boot slot0:cat5000-sup3_6-2-2.bin
