Cisco 6509 Switch IOS Problem
rsjavahar
HI
i have 1 6509 with these modules
ws-x6k-sup1a-2ge 2 modules x
ws-x6248-rj-45 2 mobules
ws-x6348 3 modules
ws-x6624-fxs 1 module
the problem i have is there is no IOS/ Catos installed in the Boot flash or slot0. can any one suggest me for the sutable ios and CatOS , please its very very urgent
glen.grant
You don't mention how much DRAM the SUP1 card which is necessary to determine what code you can run . Some early modules only had 64 meg of dram only had 64 meg installed while later ones had 128 meg. If it only has 64 meg I would go with cat6000-supk8.7-4-3.bin . If it has 128 you can use anything you want with the caveat being you read the release notes for any rommon requirements . It want GD code use the latest 7.6 code which I think is like 7.6.17 at this point.
sup1 DRAM is 128 flash card is 20 mb . i installed cat6000-supk8.7-4-3.bin through Xmodem. after that i am getting errors. they are
System Power On Diagnostics Complete
Boot image: mkseg1:a000e040
In Local Test Mode, Synch Failed. Retries: 4
WARNING: Pinnacle has not synchronised
Local Test Mode encounters Minor hardware problem in Module # 1
Runtime image not stored in the flash. Flash sync disabled.
Running System Diagnostics from this Supervisor (Module 1)
This may take up to 2 minutes....please wait
Pinnacle Synch Failed. Retries: 4
Use 'show test 1' to see results of tests.
Cisco Systems Console
%SYS-1-SYS_ENABLEPS: Power supply 1 enabled
Enter password: %SYS-5-MOD_PWRON:Module 3 powered up
%SYS-5-MOD_PWRON:Module 4 powered up
%SYS-5-MOD_PWRON:Module 5 powered up
%SYS-5-MOD_PWRON:Module 6 powered up
%SYS-5-MOD_PWRON:Module 7 powered up
%SYS-5-MOD_PWRON:Module 9 powered up
%SYS-3-MOD_MINORFAIL:Minor problem in module 1
%MLS-5-FLOWMASKCHANGE:IP flowmask changed from DEST to FULL
%MLS-5-NDEDISABLED:Netflow Data Export disabled
%MLS-5-MCAST_STATUS:IP Multicast Multilayer Switching is enabled
WARNING: Switching bus not synchronised
%SYS-5-MOD_OK:Module 1 is online
%SYS-5-MOD_REMOVE:Module 4 has been removed
%SYS-5-MOD_INSERT:Module 4 has been inserted
WARNING: Module 3 Pinnacle has not synchronised
%SYS-3-MOD_FAIL:Module 4 failed to come online
after this how can i copy this file in to the bootflash/Flash . when i applied the command which boot its showing
Console> (enable) whichboot
Boot image name is 'mkseg1:a000e040'.
Console> (enable)
