01-27-2003 09:14 AM - edited 03-02-2019 04:33 AM
I have IOS c2600-js-mz.122-6c on a 2621 chasis and I am trying to make it dial out on the BRI interface. I have set 2 BRIs together to back the leased line.
The dial does NOT work and what is puzzling me is the foll line:
Jan 27 16:53:12 UTC: ISDN: get_isdn_service_state(): idb 0x8217E990 bchan 2 is_isdn 1 Not a Pri
The complete debug looks like foll :
Jan 27 16:53:12 UTC: BR1/1 DDR: Dialing cause ip (s=xx.xx.xx.xx, d=yy.yy.yy.yy)
Jan 27 16:53:12 UTC: BR1/1 DDR: Attempting to dial 2883752
Jan 27 16:53:12 UTC: ISDN BR1/1: Outgoing call id = 0x8070, dsl 9
Jan 27 16:53:12 UTC: ISDN BR1/1: Event: Call to 2883752 at 64 Kb/s
Jan 27 16:53:12 UTC: ISDN BR1/1: process_bri_call(): call id 0x8070, called_number 2883752, speed 64, call type DATA
Jan 27 16:53:12 UTC: CCBRI_Go Fr Host InPkgInfo (Len=22) :
Jan 27 16:53:12 UTC: 1 9 1 80 70 0 4 2 88 90 18 1 83 2C 7 32 38 38 33 37 35 32
Jan 27 16:53:12 UTC: CC_CHAN_GetIdleChanbri: dsl 9
Jan 27 16:53:12 UTC: Found idle channel B1
Jan 27 16:53:12 UTC: ISDN BR1/1: trigger_calling_called_debug, dsl 9, callref 0x41, outgoing TRUE
Jan 27 16:53:12 UTC: CCBRI_Go Fr L3 pkt (Len=32) :
Jan 27 16:53:12 UTC: 2 1 41 98 18 1 89 95 2A 16 80 88 7 32 38 38 33 37 35 32 80 1 D 80 1 14 80 1 14 80 1 14
Jan 27 16:53:12 UTC: ISDN BR1/1: LIF_EVENT: ces/callid 1/0x8070 HOST_PROCEEDING
Jan 27 16:53:12 UTC: ISDN BR1/1: HOST_PROCEEDING
Jan 27 16:53:12 UTC: ISDN BR1/1: HOST_MORE_INFO
Jan 27 16:53:12 UTC: CCBRI_Go Fr L3 pkt (Len=8) :
Jan 27 16:53:12 UTC: 45 1 41 96 8 2 82 EF
Jan 27 16:53:12 UTC: ISDN BR1/1: LIF_EVENT: ces/callid 1/0x8070 HOST_DISCONNECT
Jan 27 16:53:12 UTC: ISDN BR1/1: Event: Call to 2883752 was hung up.
Jan 27 16:53:12 UTC: ISDN BR1/1: process_disc_ack(): call id 0x8070, ces 1, call type DATA cause 0x0
Jan 27 16:53:12 UTC: BRI1/1: wait for isdn carrier timeout, call id=0x8070
Can you please help me understand what could be wrong???
To mention something: I cannot see any Q931 messages, which seems very odd to me. Could I face a switch which is not configured properly???
Please advise me.
01-27-2003 07:27 PM
Try to bounce the bri line using "shut and no shut" or "clear interface bri x/y"
and see if that makes any difference..I assume "sh isdn status" reports good layer 2 status and no calls at layer 3.
You can also try "isdn call interface bri x/y
01-28-2003 01:32 AM
I have changed the switch type WITHOUT reloading router, as it was not possible at the time.
I have just reloaded the router and now I can see Q921 an Q931 messages when doing a debug. So, it looks like the reload has cleared the issue. It seems that the ISDN switch type change MUST be done with a router reload... I know CISCO recommends clear int bri and shut/no shut when reload is not an option, but I now think reload is the best solution...
Thanx, Mihai
01-28-2003 09:38 AM
You can get away with realod as well. When you mis-configure the switch-type and if you want to change it, just "shutdown" the bri line and change the swith-type, After that "no shut" under the bri intrface should do the job..
Reload is the last weapon..
