Ethernet interface configuration
ksheetz
Cisco 2600. How do I distribute traffic between 3 logical subnets on 1 internal interface, or do i need to buy another ethernet interface? thanks
6 Replies 6
pkhatri
Level 11
Level 11
Howdy,
I'm not sure I am totally clear on what you are attempting here... If you mean how you can route traffic between 3 subnets configured on the one interface, then this should happen automatically. The interface will have its primary IP address in one subnet and the other two addresses will be secondary addresses.
If that's not what you were after, pls provide more details.
Paresh.
Thanks, I've got it. How many secondary addresses can you operate on 1 interface?
as an alternative to secondary addressing, you could also configure 802.1Q trunking. Not knowing exactly which router model you have, here is a sample config for a 2611 router with 802.1Q trunking configured on the 10MB Ethernet port:
interface Ethernet0/0
no ip address
full-duplex
interface Ethernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.10.1 255.255.255.0
no snmp trap link-status
interface Ethernet0/0.2
encapsulation dot1Q 2
ip address 172.16.20.1 255.255.255.0
interface Ethernet0/0.3
encapsulation dot1Q 3
ip address 172.16.30.1 255.255.255.0
Obviously you would also need to create the respective VLANs on the switch(es) you have connected to the router...
HTH,
GP
A maximum of 6 secondary address can given on a router ether interface. hope it helps
Thanks!
I have seen a router interface with 20 secondary addresses which worked quite well.
There is not an arbitrary limit on the number of secondary addresses on a router interface.
Rick
Rick
