Example config of LLQ between Point to Point T-1
randyclark
Does anyone have an example config of LLQ on for H323.
I have a 2600 router connecting three 2500 series routers using Ip unnumbered on the serial ports.
2 Accepted Solutions
ciscoblood
I assume you are running the p-p links, with ppp as encapsulation.
This link does shed light on configuring LLQ on p-p links running ppp
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080094660.shtml#subfirsttwo
VoIPover Serial (leased lines), using HDLC encapsulation, is a practical, easy-to-implement-and-configure choice for T1 link speeds and higher. VoIPovSerial (leased lines), using MLPPP encapsulation, offers fragmentation and interleaving (LFI) to ensure acceptable voice quality on slower link speeds down to 56K.
Depending on the speeds, you might want to choose ppp or HDLC encapsulations.
ciscoblood
It looks like no encapsulation is running on the links. I take it that encapsultion must be used to run LLQ. Below is part of the config.
interface FastEthernet0/0
ip address 192.20.192.1 255.255.255.0
ip broadcast-address 192.20.192.255
no ip directed-broadcast
speed 100
full-duplex
decnet cost 10
bridge-group 1
interface Serial0/0
bandwidth 768
ip unnumbered FastEthernet0/0
no ip mroute-cache
decnet cost 10
mop enabled
bridge-group 1
bridge-group 1 lat-compression
interface Serial0/1
description bandwidth 768
decnet cost 10
mop enabled
bridge-group 1
