Having issue to understand TCP traffic
Mark1110
Hello, i am trying to connect LDAPS session from CIMC but not succeeded. I captured below from AD server. can someone explain me below TCP capture. I searched on net but still confuse what happen.
AD server: 2.2.2.2
CIMC IP: 1.1.1.1
Please find attached file for capture.
Appreciate any kind of help!!
Mark
8 Replies 8
as far as I can tell, the capture does not show much more than the TCP handshake and subsequently some data being pushed (PSH flag).
What exactly are you doing that generates this traffic ? Make sure your user accounts are configured correctly...
https://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/gui/config/guide/1.5/b_Cisco_UCS_C-series_GUI_Configuration_Guide.151_chapter_0111.html
Hello, i tried to login from cimc with my credentials to generate a traffic.
Mark
Hello, i tried to login from cimc with my credential to generate this traffic. Capture shows rst means force close by server?
thanks,
mark
Mark
Yes a rst is a force close generated by one of the devices.
As a first step in figuring this out I would suggest checking the AD server and make sure that it has a correct entry for the CIMC.
As a second step are there any entries in the log of the AD server when you attempt to access from CIMC?
Rick
Thank you for your reply. I am switching from LDAP to TACAC+ connection for a try now.
the issue as I see from TCP exchange traffic is
1- fragment this indicate that there is MTU mismatch
2- PSH flag appear which mean that one side buffer is full.
Mark1110
Thank you for your reply. I am switching from LDAP to TACAC+ connection for a try now to check.
Thanks for the update. Please let us know the results.
Rick
