hot standby
e-xiao
i want to make two switches hot standby.
i mean ,if any of the two swiches is bad then the other will take and continue working without stop.
can Cisco do it?
Prashanth Krishnappa
What model of switches do you have?
any model of switches,
i know Redundant supervisor engines can be used on Catalyst5000 seriers,but now i want to know can i make two same model switches hot standby?
If you have properly designed network with dual core and all your other closet/distribution switches dual attached to core switches, you can make core switches redundant. Layer 2 redundancy is taken care by Spanning tree and for layer 3 redundancy, you can use HSRP
The layout should look something like the one in the following page
http://www.cisco.com/warp/public/473/16.html#4c
