How to go back to internal power from RPS 675?
wagnerch
I do not really know how I can switch back to the internal power supply?
The situation: The power of the internal power supply was lost (eg. wrong cable was unplugged).
The RPS takes over but it looks like it does not go back to the internal power if the internal power is ready again.
Is a going back not possible without interruption?
Chris
rmcarthur
Hi Chris
As far as I know it is not possible to revert to internal power once an RPSU is providing power without rebooting the switch.
rmcarthur
Hi Chris
