i have got two Cisco routers connect with HSRP configuration. On one interface of these routers i need change group ID due to change virtual MAC address. What is the best practise for this change ? I want to avoid outage on other interfaces.
Note: I can shutdown interface where the group ID will be changed.
I was thinking about this procedure:
Remove interface from tracking on both routers.
On standby router shutdown this interface and change group ID.
On active router shutdown this interface and change group ID.
On active router - enable this interface.
Enable interface on standby router
Add interface to tracking on both roters.
Is it ok ?
