05-24-2004 01:41 AM - edited 03-02-2019 03:53 PM
Hi All,
We have 2 2600 routers.
One router has FE IP x.y.z.252 and the other router FE is x.y.z.253.
When I try to put the first command for hsrp i.e
standby 1 ip x.y.z.254, then following error it shows.
"address cannot equal interface IP address"
Will anybody please let me know why this error it is showing ? and any solution to this ?
Thanks in advance.
Sunil
05-24-2004 01:58 AM
First, try to revise the IOS SOFTWARE, perhaps this IOS not permit configuring HSRP.
If the IOS permit to configure HSRP try:
Interface Fastethernet X/X
no ip redirects
Standby 1 preemt
before to configure the standby ip XXXX.XXXX.XXXX.XXXX
05-24-2004 07:21 AM
The IOS is 12.3(3) on both the routers.
standby command works well on the other router.
But the one in consideration does give the error.
I tried to put no ip redirects and then stanby 1 preempt firstly, but still it did not work.
One more thing .254 is nowhere used.
Thanks and Regards,
Sunil
05-24-2004 05:19 AM
That error message indicates that the router thinks that the address has been used somewhere. Can you post the configuration commands on all of the interfaces of the router.
05-24-2004 11:49 AM
what is your subnet? It's not 255.255.255.252 right?
05-24-2004 05:35 PM
The subnet mask is 255.255.255.0
Sunil
05-25-2004 03:21 AM
Can You ping the x.y.z.254 ?
What is the result when You enter "show ip route x.y.z.254" ?
